Old 04-23-2016, 03:59 PM   #1
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
Originally Posted by Exiwolfman View Post
if you gone clean the throttle body ...make sure u have someone to help or a way to prop the gas pedal on full with key forward ( car off! ) since its bi-wire setup..do not force open with hand cos you will get engine code etc.
Yes, to clarify, turn key to 'ON' position (engine not running) and put a brick on the gas pedal, then take a toothbrush or something similar and spray and scrub the crap outta the inside of the throttle body, let the spray evaporate before you start the car back up and all the crud you loosened up will get burnt up and your idle should be fixed. had to do this last week on my car
z0mb13k1ll is offline   Reply With Quote
Tags
air conditioner, engine, jerking, misfire, rough idle
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
horrible idle / engine shake after car audio install Split In Car Entertainment + Electronics (audio / video / alarm) 8 03-02-2012 12:03 PM
thewifesyaris - photo scavenger hunt thewifesyaris Photo-Video-Media Gallery 0 03-01-2009 07:02 PM
