Correct - Without completely disassembling the tranny and dumping out the torque converter 3L is the max you will extract, even with pulling off the strainer.
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Automatic Trans fluid change interval? | charles nelson | DIY / Maintenance / Service | 2 | 02-08-2013 07:25 PM |
| Should I change my brake fluid? | lh59 | DIY / Maintenance / Service | 4 | 06-26-2012 11:48 PM |
| transmission fluid that indicate must change | susucosp | DIY / Maintenance / Service | 3 | 12-10-2011 11:51 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
