K3-VE
Drives: Daihatsu YRV 1.3 CXS Join Date: Apr 2016
Hello again, already changed my coolant (pink/red G12+), gear oil (GL4+ 75w90), and engine oil (5w40 semi-synthetic).
I drive a lot and the next oil change is due soon, so I was wondering if I can change to a thicker oil..? I was suprised to see TS-2 SHPD 20W-50 CG-4/SJ mineral (diesel truck oil) as the No. 1 OEM recommendation. Isn't this oil a bit too thick? Optionally, the SCT Germany website (the producer of the cheapo MANNOL german oils I always use) lists substitutes such as 0w40 fully synth and 5w50 semi-synth. Would you agree with them? Wouldn't 5w50 or 20w50 be too thick? Or is _w50 ok for a relatively worn out engine such as mine? Thanks in advance.
K3-VE |
| Tags |
| box, drain, gear, oil, plugs |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
