Old 05-17-2016, 01:09 PM   #9
Dabuu
Radical Dreamer
Drives: spiritedly.
I doubt it's a fuse. Alot of systems share a fuse, so if it was, you would see something else that isn't functioning properly. Maybe the rear door relay, but, it's (rear latch) controlled by the main body ecu.
The unlatch signal is sent to the Main Body ECU. The MB ECU then outputs a signal to the rear door motor allowing it to unlatch.
Depending on your Yaris' first date of use, and current mileage, the 36 month 36,000 mile warranty would cover it. If not, a MB ECU is going to cost alot, but that's worst case. It could be a broken wire somewhere. So unless you buy the electrical wiring diagram from Toyota, this might have to be a dealer visit.
It's not that simple to fix a stuck door lock nowadays. :P
Dabuu is offline   Reply With Quote
2012+ Yaris rear hatch curvature for spoiler yarisugi Third Gen Yaris General Discussion 5 07-10-2015 02:59 AM
Toyota Yaris Ready to Rally in 2013 TagRallySport to Run Toyota Yaris in 2013 America Tagrallysport Photo-Video-Media Gallery 7 11-15-2012 04:40 PM
What will fit in a 5 door hatch Yaris? ruby9c New YARIS Purchase Forum 16 12-31-2010 12:46 PM
