Old 06-16-2016, 12:43 AM   #1
B.B._07
Drives: 07 5dr
Originally Posted by Benghazi View Post
i change the sensor it still not work, each time i clear the code P0500 it comes back again when i drive, the car wouldn't shift the 2nd gear until the check light illuminate and the car works normally until speed 120 kph, at this speed the car look like have a speed limiter i can't give it more speed something limit the speed, and i didn't feel that 4th gear is shifted.
one mechanic says that the problem is in the transmission and the other says it's in ECM but to change it you need to change ECM and immpolizer and may items.
any one have an idea for this problem ??
The speed sensor should be a 3 wire design, with an input 12V, ground, and typically 5V max ouyput. So with a multi-meter or test light check the connector that you have 12V and ground. Corrosion at the connector is also a common thing but I doubt that's you're issue if you're in (sunny and snow free) Libya.
Gear fault on a 2009 manual toyota yaris please help! Gretch2689 UK 1 03-06-2014 01:41 PM
Yaris Gearbox gear change problem? slnko2003 General Yaris / Vitz Discussion 1 08-20-2012 01:26 PM
