![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Digital instrument cluster conversion complete
Hi all.
This project took waay longer than I anticipated but alas its complete. I have successfully hacked a digital UK market instrument cluster to work in my car. I managed to get it to work in kph like the NZ market ones but with the features of the UK one. New features: -outside temperature (had to wire up an additional sensor) -instantaneous fuel consumption -average fuel consumption -average speed -distance to empty Known issues -smart key warning does not work Thanks to CTScott for vital advice and helping to supply some parts. Check out the pics, I used techstream to get it to display stuff. |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
On my usdm yaris, the digital cluster plugged right in without any modifications to get all functions, except the outside temp which I don't use. Just too bad I'm stuck with metric system.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
I would like to have one of those digital clusters in my car and I don't mind being stuck with the metric system at all.
Roy |
The UK meters come stock in imperial (mph) so for you guys its real simple just plug and play but wrong side. You could get a european one thats LHD but I guess the Euro ones are in metric.
I can help you guys convert to imperial and even get your odometer reading correct. |
I reprogrammed the odometer for him, but could not get that unit to flip to MPH. I have done Km to mile conversions on loads of Japanese digital cluster cars, but occasionally you run into ones where the firmware is hard coded for one or the other.
hey! any ideas where I can get these clusters ? I have a 2008 LE canadian hatchback
I really doubt this doesn't fit and since I'm canadian, I prefer metric system.. please any ideas where to get one for LHD |
search ebay for "tacho yaris" specify "worldwide" location. i got mine 2 years ago from Europe, countries like latvia, Germany , are some i've seen.
http://www.ebay.com/itm/tacho-kombii...4AAOSw4HVWDS0n
#8 | |
uhm does this realy fits an LHD 2008 ? hatchback ? I dont really know a thing, aaaaand I dont wanna waste 230$ you know...
[DELETED]
#11 | |
Drives: Hazardboyride Join Date: Jan 2017
How did you wire the outside temp sensor? Can you help me? @JudgeM
| Tags |
| digital dash, instrument cluster, speedometer |
