Old 07-03-2016, 12:35 AM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
The auto trans > manual trans conversion guide
Here we go again with another big project, haha. If your Yaris has a automatic transmission and you want to know what's needed to get a manual trans in there, take a look.
1)Transmission and 75W90 fluid
2)*Axles can be reused*
3)Shift cables
4)Floor shifter assy
5)Clutch/brake pedal assy
6)Brake master cylinder for manual trans car
7)Clutch master cylinder and line to brake reservoir
8)Clutch slave cylinder, bolts and lines
9)Clutch kit and bolts
10)flywheel and bolts
11)ECM/Wiring
12)MT mounts
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-24-2009 11:08 PM
Manual To Auto bronsin General Yaris / Vitz Discussion 10 12-22-2008 10:32 PM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 02:43 AM
Manual vs. Auto littlecarlove General Yaris / Vitz Discussion 25 10-25-2006 08:45 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
