#14 |
Update:
Figured i'd post the response from the shop in fairness. Called them this morning and the manager had spoke to the tech who apparently worked on the car (no tech name was on the work order). He said he never removed the wheels even to adjust the camber bolt. To their credit, they were respectful to deal with on the phone and took the time to listen to the issue. I find it hard to believe that they adjusted the camber bolt with the wheel on the vehicle, it's near impossible to wrench those bolts with the car raised (although technically it's possible) They may very well be telling the truth, I just find it hard to believe that my wheels which I torqued to 76 ft/lbs and re torqued a week later ended up being so loose I could remove 2 lug nuts with my hands. Lessons learned, at least the alignment was done well and the car tracks better now!
| PG Hub spacers group buy | Vitz_Q8 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 45 | 11-15-2015 02:10 AM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| FS: Hub Spacers (R) /Wheel Spacers (F). Come with extended bolts. | Betrivent | Items for Sale by private party | 1 | 06-26-2015 10:41 PM |
| installing Penguin Garage rear hub spacers! | Tamago | DIY / Maintenance / Service | 101 | 05-21-2011 12:29 PM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 07:10 PM |
