Old 07-07-2016, 04:38 PM   #3
esse10
Drives: 2009 yaris 2 door
A/C
on a 2008 yr old model maybe the condenser is really dirty, check that. Does your engines electric fan come on when you turn the A/C on ?
You can't have cold A/C if the condenser is not getting air flow through it.
You know how to read/use manifold gauges? hook those up and see what the low and high pressures are before and after you turn on the A/C.
with A/C off both low and high pressures should be equalize and should be around 90-100 psi. when the A/c is turned on the low comes down to about 30-40 psi and the high go's to about 150-175psi. depending on ambient temperature.
2008 Toyota Yaris passenger side view mirror change KOOCHO DIY / Maintenance / Service 1 12-01-2012 09:52 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
