Old 08-22-2016, 10:15 PM   #34
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Originally Posted by ern-diz View Post
The 12-13 second time when stock is interesting given how many other vids we've seen of 10 seconds. Maybe the weather does play a part.
january its 20-23c/ under 73f...only cool time of the year..car flies 😅😅😅
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
How to check automatic gear transmission oil iaq DIY / Maintenance / Service 4 12-04-2008 01:50 PM
Will thicker automatic transmission oil help with pick-up ? nurburgring General Yaris / Vitz Discussion 3 08-01-2007 04:15 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Is that bad for automatic transmission? hans_fh General Yaris / Vitz Discussion 9 11-20-2006 07:25 AM
