![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Engine vibrates unevenly and the exhaust pulsates.
The car sounds sick like it is misfiring and the exhaust is pulsing. Engine vibrates! engine has 180 000 + k's. Any idea what it could be?
Is it possible to put a 2013 engine in a 07 Yaris?
2ZR swap. DO IT! Ask how!
#4 | |
AH, ok so is the a gasket there or i need to tighten the bolts? Last edited by junorico24; 08-30-2016 at 07:26 PM. |
check engine codes. ever change your sparkplugs? clean air flow sensor? CHECK ENGINE CODES!
yes, the 13 will fit in the 07 |
#6 | |
We changed the spark plug and cleaned the MAF. When he gets home today we will clean the TB and tighten the intake.Maybe there's an air leak somewhere. I don't have a code reader but check engine light did come on. |
#7 | |
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
Fixed turns out cylinder 2 coil pack was bad.
NOTE; always use OEM Denso toyota pack. |
yeah. and always use NGK or Denso spark plugs....
