Old 09-21-2016, 09:29 PM   #3
The symptoms definitely sound like a charging issue. The squeaking of the belt happening and then stopping may just be because of the temperature at the time or something getting on the belt, but a squeaking belt pretty much always mean a loose belt, and once they start squeaking they get glazed and really should be replaced.
Besides checking the belt, I would check the battery terminals to see if either is loose or has corrosion on it. The bumpy road could have rattled an already loose connection.
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
Light weight race battery. buddyjim Performance Modifications 24 01-27-2009 08:33 PM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
blinking LED light kaymm In Car Entertainment + Electronics (audio / video / alarm) 3 09-14-2006 10:05 PM
