Old 04-24-2016, 01:30 AM   #163
bairjo
Well I'm in the club...103,000 miles on my 2010. No issues here. Guess I should change the oil now...lol.
Old 05-02-2016, 11:00 AM   #164
billfires
Drives: 2010 3dr LB
Just turned 100,000 on my 2010 HB. Oil & filter changes, air filter and tires have been the only maintenance items. Bill C
billfires is offline   Reply With Quote
Old 05-02-2016, 11:56 AM   #165
texascolt45
Drives: 2015 yaris
I got 15,000 since august of last year.
texascolt45 is offline   Reply With Quote
Old 05-02-2016, 12:53 PM   #166
bairjo
15,000....Congratulations. .....You are almost there.
Old 05-06-2016, 05:13 PM   #167
jose1969
Drives: yaris d4d
Hi there!
I'm just getting 100000 miles on my '08 yaris d4d in few days....no problems until now
Edit: yesterday the battery just said goodbye and the check engine light is in the dashboard.
jose1969 is offline   Reply With Quote
Old 05-08-2016, 05:11 PM   #168
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I hit 102k on the chassis recently on my 07 sedan.
Sent from m-o-b-i-l-e
Old 06-14-2016, 12:15 PM   #169
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
I'm at 253k right now... I'm starting to wonder if I should proactively swap the alternator, fuel pump, or water pump? I have a 75 mile each way commute into town and don't want to get stranded. Car drives perfectly though!
Cosmetically my front end has been chipped all to hell by all the construction around Atlanta. I'm planning on having the front end totally repainted and using Xpel on the front. Nothing else has really taken a beating like the front... the damned main road through the city was practically a gravel for a few weeks!?!?!
firebird1999us is offline   Reply With Quote
Old 06-14-2016, 09:12 PM   #170
CB900F2
Drives: 08 Sedan
170,000Km on my 2008 Sedan... And runs and looks like a champ!..
CB900F2 is offline   Reply With Quote
Old 06-18-2016, 09:54 AM   #171
zoidberg444
zoidberg444's Avatar
110,000 miles roughly on my 06 jap made Hatchback. Pretty impressive considering mine has the 3 cylinder engine made for the Aygo in it. I really don't think Toyota designed it for being driven like its stolen every day.
Servicing, tyres, exhaust, water pump, battery and oddly enough my alternator. Its never once let me down, always done whats needed from it until i could get it to a garage. I also have a little noise that sounds like the thrust bearing might be starting to wear. But I'll wait till it gets worse to do the clutch.
I intend to drive it until it collapses into a pile of rust. If the engine blows up i will just stick a used one in.
Old 06-19-2016, 12:57 AM   #172
BLKHILLSGUY
Drives: 2011 3dr LB Polar White
I wish we got the funky little Aygo in the US. We don't get any of the kewl small cars.
BLKHILLSGUY is offline   Reply With Quote
Old 06-19-2016, 02:47 AM   #173
Tapokata
Drives: 2009 Yaris
154K on my 09 LB Clown-car. No issues other than normal service. Synthetic oil since first change, and extended drain interval (15K miles) since from 45K miles onward. No oil consumption. The 1NZ-FE is durable, and damn near bulletproof.
Tapokata is offline   Reply With Quote
Old 06-19-2016, 03:36 AM   #174
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Just curious but did you do any used oil analysis? And what brand of oil are you using?
Old 06-19-2016, 09:05 AM   #175
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
7500 miles in 3.5 months, I'm well on my way to join the club. I'm planning on switching to synthetic after 12,000 miles. I have to say, I love this little car!
Captain Yaris is offline   Reply With Quote
Old 10-22-2016, 07:51 PM   #176
BennyLava
Drives: 1987 Silverado
Where's the 300k mile club? That would be pretty cool to have. If well maintained, I don't see why these cars couldn't go 350k or more.
Old 11-04-2016, 11:49 AM   #177
nieltown
Drives: Yaris 2008 Sedan
2008 sedan - acquired in late 2009.
Had brake booster issues with it in 2011, but no other problems whatsoever since then other than a squeaky serpentine belt which was replaced last year.
Still looking for the wire harness for the head unit so I connect my OEM aux port I acquired years ago. If you have one, hook me up! I've already been shut down here but I figure it's worth a shot:
http://www.yarisworld.com/forums/sho...559#post763559
nieltown is offline   Reply With Quote
Old 11-07-2016, 04:04 AM   #178
Bony_ahmed
Drives: Toyota Yaris SEdan
115k.......still kicking ass :P
Bony_ahmed is offline   Reply With Quote
Old 11-07-2016, 07:37 AM   #179
BennyLava
161k on 2009 sedan. Bought the car with 40k on it.
My list of troubles are few. But here they are:
1. Front suspension. The shocks were somehow worn out even though the car only had 40k on it, when we got it. Replaced those.
2. I need to replace a ball joint.
3. Belt started squealing and has been replaced. Still squeals sometimes though...
4. Center console door screws backed out. Took it apart, tightened the screws, and haven't had any trouble with it staying shut since then.
5. Headlights having to be polished out.
6. Some of the rubber door seals letting go and flopping a bit. Siliconed them back down.
Old 11-07-2016, 08:34 AM   #180
nieltown
Totally forgot - had my belt replaced last year and the problem has gone away. However, this YouTube video suggests it may not be your belt at all:
https://www.youtube.com/watch?v=HRrVMtyIqIY
Forgot to mention this as well - the seal on one side (roof along top of door) has basically rotted out with just some wire there. I need to replace it - they're not expensive, I'm just a lazy dirtbag.
Anyway, right on! 161k is a lot of miles.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 12:40 PM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 05:51 PM
Japanese Mix Club Los Invitamos!!! TunTun_yariS[PR] Caribbean 0 12-12-2006 12:03 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
