![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
to answer your question, the head gasket is a large seal that spans the length of the engine. it is located below the head. (under where the intake manifold is bolted to the engine) if you replace it, the leaking timing cover that is suggested above will also be removed and resealed when assembling the head back on.
the type of gasket is a metal crush type. don't discredit 3rd party on this repair, as it's been a common repair for over 100 years, and almost every engine is built the same way and will be repaired in the same manor. |
| 3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation | keiri | Third Gen Yaris General Discussion | 26 | 09-04-2020 12:01 AM |
| DC Sports Header install and evaluation | Loren | Performance Modifications | 217 | 07-04-2017 06:40 AM |
