Old 11-18-2016, 12:23 AM   #1
CoryM
Drives: 2009 5-door, 5-speed
I believe Toyota's official answer is the M/T fluid is not required to be serviced. Gear oil does last a long time before losing it's performance: Especially in modern gearboxes/diffs. Typically water intrusion is what ruins the fluid rather than wear.
All that being said, the fluid is cheap enough that if you change it 2 or 3 times over the life of the car it's no big expense.
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Oil Change and Transmission Fluid ras3448 Third Gen Yaris General Discussion 2 09-15-2011 01:05 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
