#91 |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
^ They are 194 wedges but unless you take apart the headlight and delete the amber reflector, any color you put in there is going to come out amber.
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#92 |
![]() Drives: 2010 Toyota Yaris Hatchback Join Date: May 2011
Thank you young sir
#93 |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
All you have to do is go to superbright LEDs.com and they list all this...
#94 |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
http://www.autolumination.com/
they have some crazy crazy bulbs! led and halogen. |
#95 |
Where's my crown?
Drives: 07 self proclaimed TRD Sedan Join Date: Sep 2012
this bulb list is the shit... i was struggling on google. i shouldve known my brethren had it all figured out... 1 question though. whats the dashboard bulb size? the blank white dace has to go asap
I am the obvious resolve to the age old question, "What happens when an unstoppable force meets an immovable object?"
#96 | |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
There's quite a few numbers being thrown around.I think I can concluded the maplights are 194 wedge lights, along with the license plate. I am confused with the dome lights and trunk. I am checking superbrightLED.com and it said dome lights and trunk use this light bulb: http://www.superbrightleds.com/morei...toon/238/1131/ All three use DE3175? Last edited by MyzticZ3r0; 11-04-2012 at 08:39 AM. |
#97 | |
USAF_SrA_E-4
I can't find the light bulbs for the cluster, anyone know the their number? Trying to convert them into LEDs
#98 | |
USAF_SrA_E-4
Not everyone at once please lol
#99 |
Drives: Toyota Corolla Join Date: Aug 2013
Is the electric power consumption enough is I upgrade the standard head lamp with 9003XV XtraVision Halogen Upgrade: Up to 30% Brighter ? thanks.
sewa mobil |
#100 |
Drives: Toyota Echo 2001 Join Date: Jan 2014
Head Lamp ajustment
I’m sorry, I don’t know if there is already a post for this but I took advantage of this tread to ask you guys how to adjust the height of you head lamp lights, there is no adjustment bolt like other cars I had. Mine is a 2001 echo 4door AT.
#101 |
![]() Drives: 2006 Toyota Vitz RS. 5spd. Join Date: Feb 2014
very informative thread. I have a Vitz RS (JDM) which uses dual beam headlights. HID for the low beams (top) & halogen for the High's. I wanna get super white halogens which look better & are brighter but I don't know the type of bulbs to get. Anyone?
#102 |
4 years of P90X!
I got all mine here: diodedynamics.com gotta support the locals!
#103 |
#104 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
here is my bulbs. superbrightLEDs.com neo4 for HVAC and the tach is a 74 with120 degree view, 10 lumen.
http://www.yarisworld.com/forums/pic...pictureid=6080 http://www.yarisworld.com/forums/pic...pictureid=6081 |
#105 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
I'm going to add that the festoon for the Sedan is 31mm if you need a size. As for the Wedge, I noticed that there is room for a longer wedge bulb there so I'll be ordering a longer one to see if that helps back there without going to an adapter and panel setup. As far as experimenting, I'll try to put the longer one into the map light for shits and giggle to see if it will fit.
#106 |
Drives: 2007 yaris Join Date: Aug 2016
Temp control bulbs
I used T4 bulbs to replace them and changed them to blue, currently in the process changing the interior to led.
#107 | |
![]() Drives: 2011 S sedan A/T Join Date: Feb 2012
Just a thought. Will a yellow 7443 bulb fit in the rear turn signal socket? I would like the rear signal markers (in yellow) to be on together with the tail light and still function as a normal turn signal light when needed. Or is there any other work around to this? Thanks. |
#108 |
![]() ![]() Drives: 2010 Hatchback Join Date: Oct 2016
Hey guys, I purchased reverse bulbs 7440 for my 2010 Yaris liftback but it seems the reverse bulbs aren't the same size, does anyone know the proper bulb size or substitution for it?
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
| Bulb sizes for all Yaris Models | DJ_SpaRky | Cosmetic Modifications (Exterior/Interior) | 16 | 07-22-2009 10:23 PM |
| Accessory Bulb Types, anyone know? | Ayka | Cosmetic Modifications (Exterior/Interior) | 135 | 04-29-2007 08:33 AM |
