Old 12-14-2016, 09:58 AM   #1
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Oil Feed Line Question?
Hello all,
I have a 1NR-FE, and had a question about how to do an oil feed from an oil sandwich. My question is, since we don't have a cartridge filter, can anybody point me to a sandwich adapter that will work with the 1NR-FE housing? Thank you for your time!
MugenRep is offline   Reply With Quote
Old 01-26-2017, 01:23 AM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by MugenRep View Post
Hello all,
You sure you don't have the cartridge style oil filter? The 1NZ uses a 'spin-on' style making the typical oil sandwich kits easy to use. From what I've read, the 1NR does use cartridge style and not the spin on type.
Did a 'quick' search on-line and found out Toyota started using the cartridge style filter in the Rav4 in 2013. After searching for an oil relocation kit, I came up with this lil guy...
Hayden Oil relocation kit - Part: 291
May not be exact but it might help you get started in the right direction. Try searching for other Toyota vehicles that use the cartridge style oil filter and you'll prob find what your looking for.
JustDidIt is offline   Reply With Quote
Old 01-26-2017, 01:36 AM   #3
JustDidIt
JustDidIt's Avatar
Also found this: https://www.bpadapters.com/home.html
Now the 1NR isn't listed but now you know that once you convert to a spin style oil filter, the sandwich kits will be easier to setup.
https://www.bpadapters.com/applications.html
Old 01-26-2017, 07:59 AM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
or just T off the oil pressure sensor
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-26-2017, 09:04 AM   #5
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
You guys ROCK!!! Thank you so much!!!
Old 01-26-2017, 09:06 AM   #6
JustDidIt
JustDidIt's Avatar
That's what I'm gonna do.. ^
Engine oil question sim085 General Yaris / Vitz Discussion 6 09-07-2016 02:49 PM
oil cooler question tmontague DIY / Maintenance / Service 3 02-09-2016 11:01 AM
A question about oil change? mf4361 DIY / Maintenance / Service 4 08-24-2013 12:00 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
