Nice. I still trip out on how I actually felt an improvement with the K&N - but not until the ECU was reset.
#2 | |
Funny thing is with the FR-S, I felt a negative difference with a SRI. Loss of power, loss of driveability, bogging down. Went back to the K&N drop in for it (which I felt a positive difference from the OEM filter). |
#3 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Also did you remove the carbon trap out of the air lid yet?
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#4 | |
How interesting.
Yeah, I guess the FR-S intake is pretty efficient and optimized. It has a duct that leads to the front bumper to pull in fresh/cooler air. There's not much restriction in the intake system either, so a drop in filter is all you really need for the FR-S unless you want to get rid of the intake noise generator and/or dress up the engine bay.
For me, it just wasn't worth it. I don't drive in the top end very much, so any "gains" that an aftermarket intake could potentially give in the FR-S wasn't worth the sacrifice of abysmal low end performance. With the stock intake, bumper to bumper traffic is manageable, and flooring it from a standstill is possible. With that Injen SRI, bumper to bumper was horrible because of the heat soak (engine would almost stall out). Flooring it from a standstill was impossible. Engine revs, but then would bog down and car wouldn't accelerate, just bucks. Totally not safe in an emergency situation. |
I can see how it wouldn't be.
Replaced the RC car antenna with an OEM Honda 7" antenna.
![]() I could not find any plastic ducting though. I'll have to keep looking for that (especially for the same diameter as the silencer tube). Last edited by Kaotic Lazagna; 09-29-2018 at 07:30 PM. |
Obsessed with 1.5L
High pressure air is better then low pressure. You can probably pull it off with mainly a 90* bend to face forward. I think its pretty much a straight shot past the fans. But then you must consider possibly using reflective heat wrap to help with the heat coming off the radiator.
Its something Ive always wanted to try and just never got to. I used to run a 'hot air' duct that took air off the exhaust side to help reclaim lost MPG during the winter. Killed power but hey 50+ during winter on winter fuel Thats how I know the 3" clamps on lol
#11 | |
Considering I sit in stop and go traffic on pretty much a daily basis, I don't want to have to deal with heat soaking (which was what I was afraid of in your idea). Plus, I won't be using the snorkel at all. Right now, I'm fine with the opening by itself since it's been cold lately, but once warmer temps start again, I must have that opening filled with the ducting work. Are there any high pressure areas on the driver's side? How can you find out where high pressure areas are at anyway? |
Obsessed with 1.5L
Basically any source of air from ahead of the radiator/condenser. About 1/4 of the surface area of the heat exchangers actually flow air...so all that extra air needs to go somewhere. This is where most OEMs source outside higher pressure air to aid in performance
#13 | |
#14 |
Obsessed with 1.5L
Yeah same pricipal. We do not have a cowl quite like them.
Ive seen FiST cars with a cowl intake...maybe Ill take a look at mine tomorrow and see if thats feasible. But yeah a path with direct access to air ahead of the radiators will do the job
#15 | |
I'll have to take a look around the radiator on the driver side to see where the best access would be. But first thing's first, didn't realize the OEM battery in the FR-S is weak, so after not driving it for 9 to 10 days, I went to start it and was denied (lol). So I gotta a find a jumper pack (don't own one and no longer have cables). |
#16 |
So I tried looking, there's really no way to get in front of the radiator. I might be forced to pop off the driver side fog light cover and route the ducting to that opening. I'm thinking that should be a high pressure zone anyway since many people use that location on cars for brake cooling.
#17 |
Radical Dreamer
Drives: spiritedly. Join Date: May 2016
Fiesta ST.
Yay, I contributed. :P
Enjoy Family Car Sports |
#18 |
| Finding Remote/Iginition Wire 2016 Hybrid | drdyzio | Third Gen Yaris General Discussion | 1 | 11-14-2016 05:34 AM |
| Help finding part number | joell | DIY / Maintenance / Service | 19 | 01-06-2015 02:41 PM |
| Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) | chalked | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 01-26-2013 02:29 PM |
| need a hand finding these spacers | mr_miles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 12-11-2011 08:18 PM |
| I need help finding 17's for my ride | Stoln | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-18-2009 07:21 AM |
