#37 |
That looks correct. 5 pin connector with 4 pins used. Red, blue, white and white/black wires.
#38 |
Great. :(
Can one get ahold of a receiver without spending an arm and a leg?
If it aint fixed, don't broke it.
#39 | |
You don't want to know what the dealer price is, but may be able to find one for a reasonable price at a junk yard.
#40 |
Thanks CTScott for all the help.
#41 | |
![]() Drives: Red Join Date: Mar 2011
Hi, so having an immobolizer indicates that you do have the keyless system?
Many Many Thanks |
#42 |
Drives: Yaris 07 Join Date: Mar 2012
trouble with step 8
Hi there,
I have a Yaris 07 HB and trying to program it using your steps. However, step 10 doesn't work on my car. The car doesn't respond back to me and I cannot get it working. What should I do now? Thanks |
#43 |
![]() Drives: 2008 Yaris Sedan Join Date: Oct 2013
Wow, for the price of the remote module I can put a compustar remote starter in my like new yaris instead? Thanks for the info on the module, it makes the decision easier.
#44 |
Drives: I love toyota Join Date: Nov 2013
Keyless programming
http://programkeyfob.com/ provides free programming instructions for your cars and trucks. They do not have them all but they do keep adding them.
#45 |
![]() Drives: 2006 Yaris 3DR Hatch NCP91R Join Date: Dec 2013
Just wanted to say thanks and that this worked for me.
For those in Australia / similar don't worry about the FCID either. If you purchase from an Ebayer from Taiwan / Japan or similar (ask them before you purchase) you should be fine. I was told the FCID is a North American thing. Edit: Only tricky part is the type of transponder chip in the key. If it is an OEM / Toyota transponder you will need someone with a specific tool and access to your car. Aftermarket transponder chips can be copied without access to the car, but it all depends on the machine they use. Wasn't as easy as I would have hoped after getting the key to properly open my car, the real challenge was getting the transponder copied! Last edited by aa11; 01-07-2014 at 01:34 AM. |
#46 |
![]() Drives: '07 3d, '10 3d, '12 3d Join Date: Jun 2015
Thread revival alert....
I got a transmitter key from ebay, the code in the listing matched that in the working key I have, though nothing in the package or in/on the new key has a code on it. Anyway, tried the above procedure and got the lock click 'confirmation'- tried the button pressing on the key and nothing. Tried again, but this time didn't get the lock clicking to indicate it was in program mode. I've tried the process a couple times now and can't get the confirmation. My original remote key is working, though. Is getting it into program mode a one-shot deal? |
#47 |
![]() Drives: Echo 1.5l silver sedan Join Date: Nov 2013
Bringing this one back from the near dead.
Unsure about stating a new page for the same topic. I have a 2003 Echo, 1.5l 4door. No remotes. It has central locking and I've located the door control module, and I've wire counted it to the attached Haynes manual, I've done the dance to get into remote programming mode (although I get two cycles for add, and 4 for rewright) I've been to Toyota and they would sell me a key with buttons for $200NZD Can someone please advise me on the FCC ID I would require when purchasing remotes from eBay? Someone on here said FCC Id is an American only thing, I'm in New Zealand could someone confirm?I've been to the wreckers and they let me try to program remotes they had found but no luck - could this be because they need to un assigned somehow before being programmed to me car? Thanks for your help Michael. ![]() Sent from my iPad using Tapatalk |
#48 |
![]() Drives: Toyota Yaris 2007 Join Date: Dec 2016
Just wants to say thank you to everyone who provided great information on this forum. 2007 Canadian Yaris, base. Already know no chip in key, as I got it cut at Canadian with no trouble. Wanted another remote. Ordered one on Ebay based on existing one's FCC ID. Came with a battery. Found that out after prying it open and damaging the plastic somewhat. Programmed it per forum instruction. Had to try a few times. Forgot that the ON position is one step after ACC. Now my fiance and I both have remotes. Cost 40 cad shipped to Canada. Note that you do not need to cut the key to program it. Mine is programmed now, but not cut yet.
Sent from my LG-H831 using Tapatalk |
#49 |
Drives: Vitz RS 2005 Join Date: Mar 2018
Is there a way to program the key fob of a Vitz RS Japan Model SCP90 with Start/Stop button? Car doesn't take ignition key, only Start/Stop button.
#50 |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2018
Hello everyone,
I am searching for a remote key because i have only 2 silver keys for my 2007 Yaris Sedan. In the owners manual it says that the FCC ID is MOZB41TG and my ignition switch is all metal so i think that I have non-transponder keys. I checked if i have the receiver at the C-pillar and its there. In my search in google i found that we have keys with dot, a letter or nothing stamp . Whats that ??? I dont know if the original key had any stamp. Could please someone help me find the proper key ??? |
#51 | |
Hello Richard, could you please provide me with a link of the remote that you purchased ??? |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| DIY KEYLESS ENTRY on Power Liftback? | TC-LIFTBACK | DIY / Maintenance / Service | 0 | 08-23-2006 09:57 AM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
| Should I add remote key less entry? Options | YotaYarisUSA | General Yaris / Vitz Discussion | 13 | 05-02-2006 05:06 PM |
| FS Various OEM keyless Remote | riceboy | Items for Sale by private party | 0 | 04-14-2006 02:42 PM |
