Old 01-24-2017, 09:39 PM   #1
SirDigby
Drives: 2007 yaris 3 door
wow you bought both? that's crazy. do you have to do emissions testing? if not you can get some pretty aggressive cam shafts. (and as always, forced induction) there is a few good lightweight flywheels available out there. the exhaust has 2 catalytic converters, and the second one is not monitored. exhaust work frees up some pep. removing the back seats and rails frees up quite a bit of weight, depending on your passenger needs.
Old 01-24-2017, 09:51 PM   #2
SlowVitzRS
Drives: 2005 Vitz RS Manual
I would like to retain car as stock as possible ;).
There are no emission testing in NZ (crazy!), just a visual check.
SlowVitzRS is offline   Reply With Quote
Old 01-25-2017, 03:46 AM   #3
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Mine has the factory 15inch rims and stock size tire and 180000km and it revs out without hesitation
I dont know the weight difference of a NCP13 with a NCP91 maybe it gained a few kilos..
Stock factory figures where 0-100km/h 9 sec and 190km/h at the limiter and about 107bhp.
I would still check for compression though as I am weird like that
ncp13 is offline   Reply With Quote
Old 01-25-2017, 05:56 AM   #4
SlowVitzRS
Well, my wife's IST (NCP61 same gen as your NCP13) is fine as well.
Will see how it (vitz rs) behaves with 1ZZFE throttle body...
Regarding compression: there is no need to check it, as it does not consume oil, there is no blow by, there is no idle issues, oil is clean etc.
What I believe has happened is that Toyota was lazy and used the same CVT safe tune/throttle map on manual car. While throttle response on CVT equipped car is not important on manual car it is somewhat important (unless you hate driving).
If I wanted a boring car I would have bought an automatic Tiida for half price.
Regarding performance difference between two - yes Gen2 is slower than Gen1 due to 80kg difference (Gen1 950kg vs Gen2 1030Kg). This difference would not explain anaemic throttle response.
What I am saying is that toyota took all the fun out from the engine with their very conservative tune. Bloody 3 cylinder Sirion is more fun to drive than this thing.
Old 01-25-2017, 09:07 AM   #5
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Well if emissions is not a problem in NZ maybe you should backdate your ecu and throtle to gen 1 :)
Or try those kits that remove the lazynes from the systems with e-throtle.
Good luck
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 12:25 PM
Toyota yaris hatchback headlight fits on Vitz 2005? urguardian Cosmetic Modifications (Exterior/Interior) 2 09-11-2014 04:46 PM
Vitz 2005 Battery mudi General Yaris / Vitz Discussion 0 09-07-2011 02:28 AM
Toyota Vitz 2005 1.3L Auto Air Filter technoguy DIY / Maintenance / Service 4 01-11-2011 02:45 AM
Vitz 2005 in UK. lappie General Yaris / Vitz Discussion 0 03-12-2006 10:02 PM
