Old 01-27-2017, 11:47 AM   #3
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
I hate to be a bugger but a missfiring cylinder could be from a bad injector , bad ignition coil, spark plug , burned valve , and low compression on the specific cylinder etc...
Did he swap ignition coil with another cylinder?
P0301 is missfire on cyl #1 p0302 cyl #2 .... Etc and p0300 random misfire..
Check the health of your engine with a leak down or compression test. That will help you with diagnosis of your symptom too
Otherwise find a used 1nz engine and grab it :) its your cheaper option
ncp13 is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
Big engine trouble (FYI)... Goose General Yaris / Vitz Discussion 31 10-16-2006 03:43 PM
