Old 01-29-2017, 06:33 AM   #5
dogsridewith
Drives: 2007 2-door hatchback
Short resistance headlight bulb lamp conector
? Some kind of short and/or poor contact (high resistance) in the connector. (A poor contact makes heat, which melts plastic which lets things move and may start to sputter metal and/or let conductors touch and short.)
Also wondering about ground--if the ground leg becomes bad somewhere (wiring/connector/lamp-terminal), can the bulb holder or bulb base ground through metal or metalized plastic?
(A wiring short causes high amps...why fuses blow. A bad (high resistance) connection causes lower amps, but some of the energy (voltage x amps) gets turned into heat at the connection.)
Tags
headlight issue, high beam indicator light
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Replacing headlight bulbs in under 5 minutes without removing the bumper 07liftback DIY / Maintenance / Service 0 01-23-2015 11:11 AM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
