Old 02-01-2017, 08:34 PM   #18
Chip Whitley
Drives: 2007 Auto Hatchback
did you get any of the maintenance records with the car? Do you have any idea when the oil was last changed? Did you have your mechanic look it over before you bought it?
Yes, I had my local mechanic check it out before I made the purchase. The only thing it needed was a new muffler which I had put on the day after I bought it. It's got the little window sticker from Grease Monkey which shows the oil was last changed in December and I've got roughly 500 miles to go until the next service. The air filter looks almost new and I don't see any cracks or leaks in or around any visible hoses. I'll try resetting the computer and let you guys know if I see any improvement. Thanks again for the advice so far guys.
Chip Whitley is offline   Reply With Quote
