Old 02-19-2017, 02:42 PM   #1
bronsin
bronsin's Avatar
There is a very close fit on the wheels between the hub of the brake drum/rotor and the wheel itself. Im thinking if you put anti seize on this spot there woudnt be a problem. Put it on the hub and on the wheel.
I see you live where theres a lot of salt/snow on the roads in winter. Thats the problem.
Good luck and tell us what happens!
Old 02-19-2017, 03:56 PM   #2
vwhugger
Drives: 2008 and 2012 Yaris 2dr
I'll give that a shot next time. It'll be a while before I'll know though. One other thing, I was thinking of opening the center hole of the wheel a bit also.
vwhugger is offline   Reply With Quote
Old 02-19-2017, 05:29 PM   #3
bronsin
bronsin's Avatar
[QUOTE=vwhugger;792585]I'll give that a shot next time. It'll be a while before I'll know though. One other thing, I was thinking of opening the center hole of the wheel a bit also.[/QUOTE
If you do open the hole just file a little. I think the close fit is to ensure concentricity.
No one else does that though, in my experience.
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 05:20 PM
Wheel well removal? yaris1F8 DIY / Maintenance / Service 6 12-01-2013 06:13 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
