Old 03-05-2017, 03:46 PM   #19
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
I filled up at CO-OP and my power sucked.
Never again
Cartel is offline   Reply With Quote
Old 03-07-2017, 05:10 PM   #20
B.B._07
Drives: 07 5dr
Never again
Well I guess you can blame Top tier gas.
All grades of Co-op High Performance Gasoline are Top Tier Certified and are available at all Co-op Gas Bar locations in Western Canada.
http://coopfuel.ca/wps/portal/crs/co...8-32d900432258
In Canada, Chevron Canada, Petro Canada, Shell Canada, Esso, Tempo, CO-OP, and most recently Costco Wholesale, have attained the designation.
https://en.wikipedia.org/wiki/Top_Ti...rgent_Gasoline
Old 03-07-2017, 06:40 PM   #21
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^^ So, you think top-tier gas is to blame? That's interesting.
Old 03-07-2017, 09:42 PM   #22
B.B._07
Drives: 07 5dr
Note the rolls eyes emoji indicates sarcasm. I do think that many people over think and show too much brand loyalty when buying gasoline which is basically a commodity.
Old 03-07-2017, 10:53 PM   #23
kimona
kimona's Avatar
^^^ Okay. I get it now. Thanks.
I always make a point of buying top-tier gas for my cars. I just thought it was better for the motor and fuel economy.
Old 03-08-2017, 12:13 PM   #24
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
If I'm not mistaken, Costco is top-tier. For what it's worth, I thought to try it when we got our membership, waited in a long line and although it was cheaper, I got less mpg that tank.
I tend to stick with Chevron.
On Instagram
On Wheelwell
Old 03-23-2017, 10:57 PM   #25
SirDigby
Drives: 2007 yaris 3 door
so there is a less-than-3 year old Murphy's near my house that I always fill up at. it's cheap and convent. my father was talking about how terrible their fuel is, so I filled up at the shell for the last 2 weeks that's kind of a pain to get to and is all old and 80's.
my gas millage increased 4.6mpg (1.96km/l) I can't believe spending an extra dollar got me an extra 50 miles. I guess it's cheaper too...
Old 03-24-2017, 01:22 PM   #26
Hershey
SUNOCO is becoming a Top Tier gas on April 1st . https://www.sunoco.com/quality-fuels/ultratech/
Old 03-24-2017, 08:14 PM   #27
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
No complaints using Shell gasoline. I have been averaging 41.1 MPG for the last 1.5 years combined, even with the A/C running half of that time. Better than I was expecting when I purchased my Yari.
Kalispel is offline   Reply With Quote
Old 03-27-2017, 05:25 PM   #28
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Is this top tier gas only available in the USA? as here in Canada theres no mention of it and most people here would be hard pressed to name a top tier station/brand or even describe what top tier means. One would think if this top Tier gas was superior in some way gas companies would be advertising such an advantage.
Have Yaris will travel..
Old 03-27-2017, 05:39 PM   #29
tmontague
tmontague's Avatar
I thought top tier was a North America thing, someone can correct me if I'm wrong.
I used to always use Shell and was happy with that, now that I moved to a different city I now use Esso since it's close and is top tier as was Shell.
Old 03-27-2017, 09:11 PM   #30
SirDigby
this lists a few in Canada
Old 04-24-2017, 10:36 AM   #31
Nu18F
Drives: 2011 Yaris
valve deposits - Top Tier 34.1mg vs non TT 600.6mg
Here's more on the subject. I like the port injection of the Yaris over Gas Direct injection. GDI engines that delay the intake valve closing via variable valve timing just let's the gases back into the intake port with no chance of a fuel injector spray "upstream" to clean the back side of the intake valves.
https://www.aaa.com/AAA/common/AAR/f...ull-Report.pdf
Nu18F is offline   Reply With Quote
Old 04-24-2017, 09:35 PM   #32
SirDigby
that is true, but also most GDI engines recommend using top tier fuels...
my fuel millage was up another 2.1 mpg last tank...
Old 05-03-2017, 01:58 AM   #33
http://www.fuelly.com/car/toyota/yar.../07vios/544075
What I'm doing so far. I don't do advanced hypermiling techniques anymore either, I just stick with Shell (and when I need to, 76).
Old 07-22-2017, 11:28 PM   #34
kcanaj
Drives: 2007 yaris sedan
Does anyone buy gas at Sam's club locations, any issues?
kcanaj is offline   Reply With Quote
Old 07-22-2017, 11:49 PM   #35
kimona
kimona's Avatar
^^^ I don't buy gas at Sam's Club because it's not top tier gas.
Old 07-23-2017, 11:40 AM   #36
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
I might be an outlier here but tried shell a few times since t-mobile Tuesdays had promotions for $0.25 off each gallon at shell.
I usually fill up at Costco but with shell, The torque felt about the same on my 5 speed yaris but my mpg dropped from 34mpg to 30mpg. I tried filling up at different shell stations with the same result. I can maintain about 34mpg with chevron gas but I just can't figure out why my mpg is much less with shell.
The 76 near my house produced the same results as well.
07liftback is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 03:57 PM
How to save on $4 a gallon gas this summer fnkngrv Off-topic / Other Cars / Everything else Discussions 1 05-26-2011 07:07 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
