Old 08-10-2015, 04:09 PM   #55
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
Finally got second motor so can begin the cylinder boring, new camshafts and pistons/rods
Will be getting rid of extra parts that came with the engine, So far it looks like
Throttle body
Exhaust manifold
Stock clutch
Plastic engine cover (slight crack in it)
and if anyone wants the Intake manifold can have it for shipping cost but it got damaged in transit and has a 1 inch hole in number 1 runner
as parts come off will be putting them in the sales area
scod4025 is offline   Reply With Quote
Old 04-08-2017, 02:08 AM   #56
rabbito
rabbito's Avatar
old thread but beautiful write up...have similar mods and still having fu*ken idling issue after adjusting with allen wrench screw...sigh
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Blitz install has begun!! wildmongoose26 Forced Induction Forum 6 03-20-2013 09:41 PM
yaris mods have begun... matrixmanvvtl_i Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 03:26 PM
