![]() Drives: Blue hatchback 2 door 2008 yar Join Date: Sep 2016
Stroker 2nz with 1nz pistons?
Hey guys, i`ve been wondering if i could make more displacement out of my 1.3 by porting and changing to 1nz 1.5 pistons. Does anybody know? thanks
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
It would be easier to do a complete engine swap. The 2NZ and 1NZ have the same cylinder bore, with the 1NZ having a longer stroke.
I think you will find the 1NZ block is a bit taller to accomodate the longer stroke, so you would need custom shortened conrods to fit a 1NZ crank into the 2NZ block without the pistons hitting the head.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#3 | |
But because you`re telling me that the bore is the same i guess the 1nz has more displacement only because of the longer stroke alone? So to do something like im planning I would have to replace head or block, conrods, crank, etc.?
Changing the pistons won't change the displacement. I don't know if the 1NZ and 2NZ use the same pistons.
There are a number of people on the forum who have installed 1NZ-FXE pistons from the Prius into the 1NZ to raise the compression. Perhaps someone can check the part numbers for 1NZ and 2NZ pistons..
^what he said
Hey guys so there are no prius in my country so to get 1nz-fxe pistons would be too hard.
But there are yaris belta 1.5 1nz-fe... How can i do to bump my 1.3 2nz-fe to the 1nz-fe displacement? Does anybody know? Block and crank only? Rods, head? Thanks! |
| Tags |
| stroker |
| Performance Pistons? | rabbito | Performance Modifications | 3 | 09-21-2016 06:08 AM |
| Prius Piston swap in 1NZ (update pls) | rabbito | Performance Modifications | 2 | 06-12-2016 10:18 PM |
| 2nz pistons in 1nz | salmanghiyas | Performance Modifications | 1 | 11-15-2014 01:30 PM |
| 1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods | jtw11 | Performance Modifications | 8 | 09-03-2013 01:49 PM |
| Con rods and Pistons | leinadeb | Performance Modifications | 4 | 05-23-2010 07:30 PM |
