Old 05-25-2017, 01:00 PM   #7
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
National bearings are good stuff. It is likely a Timken bearing in a national box. National and Timken often buy and rebox from eachother. Either way it's good stuff. If it's a hub and bearing assembly it's not to bad to do. If it's just the bearing it requires a press or very precise beating with a big hammer on a solid concrete floor. If your working on gravel on your knees your better off paying the $140. IMO
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
ac compressor bearing replacement. futuredenied DIY / Maintenance / Service 5 09-12-2025 01:04 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
