![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Aftermarket parts for SALE!! DC Sports Header, Injectors, MAF adapter, Greddy EMU....
Bump!
Still available!
![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
What's thw flange retro fit for on the header?
Heat shield for O2 sensor is above mid pipe flange adapter
Sent from my iPhone using Tapatalk |
Radical Dreamer
Drives: off of T9 Join Date: Jun 2017
No header for the Yaris is CARB exempt.
If you lack driver skill, add horsepower. |
I ran this header in California and had no issues passing vehicle inspections if that's what you mean...
#10 | |
still available? Headers? |
Headers - no. Everything else - Yup!
Bump!
Bump!
2nd hand Greddy E-Manage Ultimate $350 1NZ Quantum Technologies GT12 turbo kit $1000 Included with this kit: * Garrett Turbo - GT1241 from hydrogen turbo kit * Fabricated exhaust manifold - Hydrogen Turbo Kit * Down pipe flange to be welded to stock exhaust * Fabricated intake and intercooler plumbing - 2 inch and 1.75 inch mandrel bent - Hydrogen Turbo Kit * One heat range colder Iridium spark plugs - 2 step colder NGK 2667 * Intercooler - Hydrogen Turbo Kit came with a Spearco * 2" Airflow MAF adapter needs to be welded to intake piping * eBay HKS blow-off valve (2" 50mm straight Flange Pipe adjustable SSQV SQV BOV BLACK * 1ZZ-FE injectors for 30% more fuel flow (Denso Flow Matched Fuel Injector Set for Toyota-Pontiac 1.8 23250-22080 (4)) * 10AN Universal Steel Oil Pan Return Drain Plug Adapter Bung Fitting Weldable * 4pc -10 AN Fitting Straight Black Swivel * (4) 2" to 2" Black 45 Degree Elbow Silicone Hose Coupler * 90 Degree Swivel 4AN Male to Female Fitting Adapter * 10AN 45 Degree black Swivel Fuel Oil Air Gas Hose End Fitting Adapter * 4AN Male Flare To 1/8" NPT Pipe Thread Straight Black Aluminum * (2) Black AN10 Nylon And Stainless Steel Braided Fuel Oil Gas Line Hose -10AN * (2) AN10 45 Degree Swivel Oil Fuel Line Hose End Fitting * 10AN 90 degreeTurbo Oil Pan / Oil Return Drain Plug Adapter Bung Fitting no Weld * Black 8AN Female to 10AN Male Flare Fitting Expander Adapter 8AN to 10AN * 1/8 NPT Hex Head Pipe Plug Fitting Black * 4AN to 1/8'' NPT Straight Adapter Pipe Fuel Oil Air Fitting Black Color * 1/8" BSPT Oil Pressure Sensor Fitting * Universal Polished 2'' 51mm Aluminum Intercooler Pipe Kit * (2) 1.75-2" 3-PLY universal reducer turbo/intake piping connector black silcone coupler * (3) 1.5" TO 2" 3-PLY universal straight turbo/intake piping connector black silcone coupler * (1) 1.75"-2" 90 degree reducer 4-PLY straight turbo/intake piping connector black silcone coupler * (4) 2" 3-PLY straight turbo/intake piping connector red silcone coupler * 2" 52mm PSI Universal Digital Boost Vacuum Gauge Meter Car LED Red & Blue * 2" 52mm Universal Digital LED Car Oil Pressure Meter Gauge Red & Blue * Turbo Water Feed & Return Line Kit Garrett GT12 GT1241 * Turbo Oil Feed & Return Flange Garrett GT12 GT1241 4AN Feed / 8AN Return * Universal 36" steel oil feed linke kit 1/8 NPT |
is that emanage the 1nz specific one?
My casual google skills leads me to believe its a boomslang harness for the NZ. I might have to hit this up soon. It's /Piggyback/ style allows it for STS class racing
#17 | |
Sounds good. I’m in no rush to sell, may end up using this for my 2GRFE build. MRW makes a boomslang for it and the 2GRFE to work with the EMU. |
ALL SOLD!
1ZZ 260cc (1NZ are 200cc) Denso Flow Matched Fuel Injector Set for Toyota-Pontiac part # 23250-22080 (4) Never Installed. $50 - SOLD! China KnockOff 2" 50mm straight Flange Pipe+ ADJUSTABLE SSQV SQV Blow Off Valve BOV II 2 BLACK $35 - SOLD! Toyota MAF adapter/flange that is ready to be welded to 2" piping $50 - SOLD! 2nd hand Greddy E-Manage Ultimate $350 - SOLD! 1NZ Quantum Technologies GT12 turbo kit $1000 - SOLD! Please lock thread. |
| FYI: Aftermarket parts from Japan (NCP131) | yarisugi | Third Gen Yaris General Discussion | 26 | 01-30-2016 06:43 AM |
| FS: Aftermarket parts (need to pass SMOG) | biggestsack | Items for Sale by private party | 37 | 06-09-2013 11:31 PM |
| your used or unused aftermarket parts | savister | Willing to Buy by private party | 6 | 04-29-2010 04:16 PM |
| Problem with Yaris aftermarket parts manufacturers | GMKing | Performance Modifications | 11 | 09-14-2009 12:08 PM |
