Old 06-20-2017, 10:11 PM   #1
southpaw
Drives: 2007 Toyota Yaris
Engine Heat Temp light comes on after radiator flush
Hello Yaris world,
We just got used a 2007 Yaris with 88k miles and have an engine heat temp light that keeps coming on after driving a short distance or idling for a short period of time.
It ran fine until today when we decided to change the engine oil to full synthetic and flush the coolant in radiator. We changed the coolant because it didnt look like there was any in there, so we flushed it and added supertech 50 50 coolant and pre mixed with water. I know the manual recommends Toyota specific coolant but all the manufacturers do that and I never had any problems with vehicles in the past.
Do I need to flush the coolant and get toyota specific coolant? Could the thermostat be stuck or have gone bad during the coolant change? Any ideas what else it could be?
Thanks in advance for your help.
EDIT = Just pulled the thermostat out and tested it in boiling water and it opens up. Pull the stat out and run under cold water and it closes. Kind of points me towards toyota proprietary coolant being the issue. Any confirmation on this?
southpaw is offline   Reply With Quote
Tags
engine heat temp
Engine light flashing on cluster momentarily? Garth g. DIY / Maintenance / Service 7 12-23-2016 10:38 PM
Amber engine warning light Littleloz2016 General Yaris / Vitz Discussion 3 12-16-2016 05:42 PM
Check Engine Light disabled by previous owner, need help to re-enable it. Bajan_Yarisman DIY / Maintenance / Service 2 11-03-2016 11:16 PM
Check Engine Light on at 32k kilometers? caper26 DIY / Maintenance / Service 21 10-16-2013 12:27 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
