Old 06-22-2017, 07:28 AM   #1
F117
Drives: 1.4 D4D
Smile D4D engine mods
Hello ppl!
I own a Yaris d4d 2013 90hp.
I could like to know if anybody have put a bigger turbo...a bigger ic....a bigger fuel injectors.
What modifications i can do to gain over 50hp?
I know about chips but i could something more effective.
THanks a lot
F117 is offline   Reply With Quote
Old 06-24-2017, 03:30 AM   #2
F117
Drives: 1.4 D4D
Anybody?
Old 06-24-2017, 11:59 AM   #3
SirDigby
Drives: 2007 yaris 3 door
we don't have the diesel in the USA, but those are the types of things you would do. i would think the first thing would be a ECU as toyota has a way of keeping things mellow. you could probably squeeze 10% gain in HP and +15% torque from stock. then when you add on larger things you can appropriately adjust for the gains. IMO
Old 06-24-2017, 12:07 PM   #4
F117
Drives: 1.4 D4D
The thing is that i have already a chip on it....but... i want more.... +50 at least...
But i can find on net one single person that have done any modification with bigger turbos etc etc in order to have someone to show the right way.....
Old 06-25-2017, 06:53 PM   #5
SirDigby
no, not chip. stand-alone computer. full engine control module. then, the largest intercooler you can fit. turbocharger might be slightly bigger, most likely a different impeller only. i wouldn't go super huge and loose all your low-end, that always sucks. stock should be close to perfect. propane injection is a good adder for diesel, so is a water/methanol injection. if you add both of those you will get your +50hp...
Old 06-28-2017, 02:19 AM   #6
alias06
Drives: 2008 Red Toyota Yaris
If you want to get 50+ more HP, buy a new car! Realistically though, if you plan on increasing the rated power by more than 50% you will need to do a lot of mods with the right supporting mods. Bigger turbo, bigger IC, tune, engine building, etc. At the end of the day if you want a car with 140 HP just buy a corolla, celica, matrix, civic, etc it'll come up cheaper in the long run.
alias06 is offline   Reply With Quote
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
Engine rebuild or engine change? big dilemma.... Elwe2k DIY / Maintenance / Service 28 02-02-2017 10:21 PM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
