Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Where are you mounting your AEM FI/C ??
The boomslang harness is not very long...are you pretty much stuck with mounting the AEM on top of the factory ecu?
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
in the trash can!
j/k i'd go with the infinity, mounted in the stock ECU location; when i add the turbocharger. |
Obsessed with 1.5L
Im glad you have the money to drop on an Infinity.
Plus it will not pass OBD2
why would it not pass?
i figure if i'm spending $3000 on an upgrade, i should spend the $2500 to make it run correctly. this is just my opinion. i believe you do things right, or you don't do them at all. |
assuming the infinity is a standalone, most etests now use the obdII port to check for engine readiness. standalone=no obdII=etest fail
This is the biggest obstacle for us wanting to go boosted on a yaris who have to pass e tests. (another big reason I chose to do a 2zr swap)
yeah i'm checking on that now. i thought the infinity had obd output....
Obsessed with 1.5L
Where are you getting 3000 for an upgrade?
Beauty of being a fabricator and getting parts at the right time for a good price. Ill be spending probably more getting the car tuned then actual money in the parts of the build. 6 years in the making not in any particular rush
Obsessed with 1.5L
The intercooler core was the most expensive part and I got it below retail :p
meh. i don't think they check that around here. the plug the car in and check readyness codes. it takes 10 seconds. then they test the fuel cap for integrity, it takes like 20 seconds....
#11 | |
connecting rods= $600 rings, pins, bearings, seals, crank balance, etc.= +$500 camshafts=+ $600 valves, retainers, springs, etc. (shims?)= +$500 head work= +30hrs. block= $200(?) total= $3000 + 30hrs. head work then, i guess you need to purchase your turbocharger and the components for that. turbocharger= $800 (a Good one) intercooler= $200 plumbing (air)= $500 (+,++) plumbing (oil)= $200 (+,++) extras= $100 (+,++) total=$1800 for turbocharger (ECU= $2500) oh, LSD=$1800 probably need the brake upgrade= $250 so, total=$9350 i guess my $3000 was way off. sorry, i'll pay more attention. |
ive always wanted to put mine in the glovebox in a plexi illuminated case along with the factory ecu.
Sent from my LG-H918 using Tapatalk |
Drives: my car is the best Join Date: Feb 2018
#14 | |
Obsessed with 1.5L
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I have the Camcon.....Yet its still in the box. I just don't trust any tuners, nor do I beleive a few more horsepower is worth the risk.
So I still run the factory ECM and an n/a engine :-| |
This is the thought that keeps me sticking with my factory ecu whenever my brain wanders into the realm of a piggyback. I don't plan on going boosted and realistically I don't want to fill up with premium since it my DD'er. In the end my net gain in hp would be virtually negligable, not worth the risk of a bad tune blowing the engine
| VVTi Control with AEM EMS-4 Question(s) | KTS | Performance Modifications | 8 | 01-01-2015 08:30 PM |
| FS: AEM FI/C unit and Boomslang PnP harness | DKN-YARIS | Items for Sale by private party | 0 | 06-12-2013 03:33 PM |
| aem EMS-4 standalone ECU | maxthehax | Forced Induction Forum | 19 | 05-23-2013 11:29 AM |
| AEM cold air intake vs Afe intake... | djgab101 | Performance Modifications | 69 | 04-28-2013 02:03 PM |
| FS: Zage Turbo kit, AEM FIC with Pnp Harness | djgab101 | Items for Sale by private party | 32 | 04-11-2013 10:42 AM |
