Old 07-28-2017, 06:19 AM   #12
Pinchlite
Drives: 2007 yaris HB
Originally Posted by FunctionSpec View Post
Check the hatchback lift strut mounts. There is an issue with them breaking on the older hatchbacks. Mine broke on the right side and I used a fix that I found on the forum. Left side is starting to go, spot welds are stretching and the hatch lift strut hits up against the body of the car and rattles like crazy. Only solution I found for the time being until they snap off is to put a gob of silicone grease.
http://www.yarisworld.com/forums/sho...ht=strut+mount
After removing everything I decided to remove brakelight (Top back window)
There is wires wrapped in thick plastic that was rattling against metal.I ziptied that sucker and issue resolved.
Pinchlite is offline   Reply With Quote
What exactly can you fit in the back of your Yaris Hatchback RaptorRacing General Yaris / Vitz Discussion 90 08-05-2013 06:37 PM
3 Door Hatchback Questions Dorkinheimer General Yaris / Vitz Discussion 12 01-16-2012 05:30 PM
will the axle back from a sedan work on a 2dr hatchback? ttr125fan09 Performance Modifications 2 05-15-2011 05:55 PM
