Better Lower Grill for Cheap!
I really do not like the "X's" lower grill. looks cheesy and does not have good coverage. I purchased a grill from the dealership (@$15) and a gutter guard from home depot for $4. flattened gutter guard.
then I trimmed mesh to fit grill and cut out space for bumper clips: then removed plastic X's and trimmed mesh to fit properly: then I used DEI SS zip ties to secure in place. I used these zips because of their durability and their super thin profile. (about 1/2mm) then a some final coats of paint and clear coat: I will post some pictures of it installed when it gets warmer out |
Hubcap Enthusiast
Drives: '09 3-door 5-speed Join Date: Jan 2016
That looks really nice! I'm eager to see what it looks like on the car.
it will go on soon. I also painted the upper grill the same gloss black, and plan to do the foglight/duct covers and steel wheels with the same black. we'll see if next weekend is 70 or 20. it might be in the exhaust shop, then it would be a week later. well, I do need to do the rear end work too, so it might be even a few weeks after that. should be in before April... :)
+1
You did a great job! I'm waiting to see it on the car.
sorry i didn't post pictures sooner!
old grill: new grill: i like how it looks! |
Nice. You could even cut out the "T" grill.
i was going to do that, but since the +09 has a black grill, and most other cars have black grills, the white bumper grill added a slight level of uniqueness...
![]() Drives: 2007 toyota yaris T3 a/c 5dr Join Date: Dec 2014
cutting out the T grille would make the bumper to be weak?
Looks very good.
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Wow. I used gutter gaurd in the grille of my 94 caravan 15 years ago to achieve that grillecraft look
Glad its still being done
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
yep. $3.95 and $12 for the SS zip ties. ($15 for a new grill so i could build it without removing first, in case i damage or something)
| Tags |
| grill, gutter guard, lower grill, mesh |
| 07-08 RS lower Bumper grill? | SirDigby | Cosmetic Modifications (Exterior/Interior) | 13 | 09-02-2016 08:07 PM |
| DIY - Adding Front Lower Grill Mesh | 33OH | Cosmetic Modifications (Exterior/Interior) | 24 | 08-13-2013 03:06 PM |
| Xa and XB lower grill dimensions ? | bladesmith6 | Cosmetic Modifications (Exterior/Interior) | 6 | 05-23-2010 03:20 PM |
| Yaris Lower Grill / Radiator Grill | Reeves360 | Cosmetic Modifications (Exterior/Interior) | 9 | 11-16-2009 08:45 PM |
| Lower Grill Replacement Idea (feeler) | counterfiend | Cosmetic Modifications (Exterior/Interior) | 7 | 09-24-2009 08:40 PM |
