Old 09-15-2017, 07:35 PM   #5
weevil
Drives: 2013 Yaris YRS
Originally Posted by kevinj93 View Post
The blue wire in that adapter is the power feed to the antenna amplifier. From memory, this is a black wire parallel to the actual antenna cable. The radio normally feeds 12v to this wire. If there is no 12v feed to this, you will have very poor radio reception. Look for a switched power output from the radio. This will possibly be labelled as being for amplifier switching. Connect this to the antenna amplifier wire.
I missed this one when I installed an aftermarket radio. Once I found it, the reception was almost as good as the stock radio.
Yep that is my understanding too, I have tested the wire and it’s definitely getting 12v but the signal is still nowhere near the factory unit.
weevil is offline   Reply With Quote
2012 YARIS HB poor radio reception code54 In Car Entertainment + Electronics (audio / video / alarm) 5 12-19-2015 10:46 AM
2006 Yaris Hatchback Replacing Stereo Head Unit help lauren24 In Car Entertainment + Electronics (audio / video / alarm) 11 07-01-2010 11:13 PM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
