Old 09-16-2017, 05:09 PM   #7
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by tmontague View Post
either get the long life pink stuff from Toyota or buy the OEM brand from Canadian Tire and you can buy it 50/50 or concentrated for a bit cheaper. Same ingredients as Toyota's stuff. I personally run it at a 55/45 coolant to water ratio and use the OEM stuff from CT in both my cars. It's good stuff.
I find the Yaris burps decently on its own. elevating the front of the car can help but typically I fill the rad until it's full and then turn the car on and continue to fill until it is full again. I then over fill the overflow reservoir and drive around for a day and let the engine get up to operating temps. I then re check the coolant and typically the overflow tank is almost empty. I'll top that up to the F line and then fill the rad if there is any space there.
This has worked for me now over 3 times without issue
Just got back from Canadian Tire with a jug of the Toyota OEM concentrated coolant. Also, dropped by the grocery store and picked up a gallon of distilled water. I have several old commercial plastic ice cream containers, one of which I have graduated with 1L increments. It's very easy to mix the concentrated coolant and water in this. I'll do a full drain and refill, run it around a bit and then do a final partial drain and fill. I think I'll pull the lower rad hose if the drain plug gives an resistance.
Hoping to get this job done later today, if I complete the rear brake job.
Car Maintenance, Service etc lijet DIY / Maintenance / Service 4 04-10-2012 08:39 PM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 10:00 PM
60K Mile Maintenance Pattycake DIY / Maintenance / Service 20 11-17-2009 03:34 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 04:14 PM
