![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Aug 2017
Look up your wire harness and see if the plugs fit in the back of the unit based on the pictures I uploaded. I do know that it will physically fit into your dash opening and you only need to swap out the side metal mounting bracket from your old unit. The car I tested was from 2007 Yaris Hatch. However, I did not try to plug it in.
