![]() Drives: Toyota Yaris RS 2011 (HB) Join Date: Sep 2016
AFE intake installation problem
Hi,
I just finished installing an AFE intake in a 2011 RS I bought 4 months ago. My problem is with the part I'm holding on the photo. It was originally holding on to the oem intake tubing close to the throttle body. Now its not fixed to anything and I don't know what to do with it. I saw on an other post someone who screwed it to the metal box right in front of the intake tubing but in my case I can't reach that point because of the length of the tubings. Any ideas? Thank you for your help. ![]() Sent from my SM-N910W8 using Tapatalk |
#2 | |
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
Pretty sure those tubes and that solenoid is used for evap purging into the intake from the canister. That said, you could get some longer tubing that is good for fuel vapors and trim the longer one. What you can do with that is it gives you a chance to move the solenoid elsewhere and secure it wherever you could. Otherwise, zip tie it is all I can think of Sent from my iPhone using Tapatalk |
I ziptied nine back when I had my 1nz. Just make sure nothing runs. It is your evap solenoid iirc
2ZR swap. DO IT! Ask how!
That's very odd that they didn't account for relocating that part. Even the crappy $50 eBay CAI that I bought to fabricobble my supercharger intake had a flange with a hole to mount the evap solenoid.
The metal bracket is screwed to the back of the solenoid, so if you're feeling crafty you could make a new mount that attaches somewhere else nearby. The bolts on the throttle body are fairly easily accessed and have some extra length to accommodate the coolant filler neck. |
Thanks for your quick reply's. It gonna be zip tied temporarily until I have more time to change the hoses. Here' another picture from a different angle before the zip tieing.
#6 | |
#7 | |
I agree with this. I recommend get crafty with it and post back! I’m looking at an AFE intake as well, I’m curious what you’ll end up doing with it Sent from my iPhone using Tapatalk |
Hmm, I see...
Drives: 2012 Toyota Tundra and Yaris Join Date: Oct 2016
I zip tied mine. been like that for 20,000 miles and so far so good
"Everything happens for a reason. Sometimes that reason is you're and idiot"
For such an expensive intake of expect afe to have figured it out...
Problem fixed! I removed the screw that hold the metal bracket from the solenoid and replaced that bracket with the angle bracket in picture 1. I had to cut a piece of plastic on the solenoid to position the bracket in the right position so it doesn't look weird. Picture 2 and 3 show you before and after removing the small plastic piece. I guess it served as a guide when fixed on the original bracket so I don't care cutting it. I then used a hose clamp to hold the metal bracket against the intake pipe. Just under the higher clamp.
![]() ![]() ![]() ![]() Sent from my SM-N910W8 using Tapatalk |
yeah then soon after you find out that the heat shield rusts up and crumbles.
| Anyone have the AFE intake? | white_rice | Canada | 3 | 03-02-2013 01:09 AM |
| AFE intake setup | goliath1812 | Performance Modifications | 1 | 08-29-2011 11:53 AM |
| FS: AFE Air Intake System (Cold Air Intake) | jjbG35yaris | Items for Sale by private party | 7 | 04-01-2011 02:58 PM |
| AFE Intake and NST 10% UD Pulley Gray | hatchbackkid82 | Items for Sale by private party | 12 | 04-17-2010 09:16 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
