Old 10-26-2017, 11:38 AM   #1
1zzVitz05
Drives: Echo 05
Originally Posted by LittleblueechofromOZ View Post
Will this be much different in an echo (04)? would the mounts be the same?
I swapped a 1zz out of a 98 corolla in my echo and it involved alot of cutting from the frame rails, but rear trans support fits the c59, dont know much about the 2zr though..
Echo and yaris are completly different the echo railsare way more narrow than the yarises..
Edit echo rails are parallele from the firewall, the yarises kinda gets in a U shape right after that, allows more room, a guy here swapped a 2zz in a 07 yaris but kept the OE 5 speed to avoid cutting the rails.
1zzVitz05 is offline   Reply With Quote
Old 10-30-2017, 04:42 PM   #2
DarkShadowFox
2zz pretty much fits in the 3rd gen too because its the same car with different body panels
Sent from my LG-H918 using Tapatalk
The 2zr-fe engine swap guide ArmstrongRacing Performance Modifications 416 08-14-2023 04:14 PM
engine swap yaris9876 DIY / Maintenance / Service 12 12-26-2013 11:27 PM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 02:05 AM
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 07:20 PM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 02:40 PM
