#451 | |
![]() Drives: Yaris Join Date: Apr 2017
That support cruise control |
#452 |
Drives: 2007 Toyota Yaris Join Date: Nov 2017
My apologies if this has been asked before. I'm going to attempt this project for my wife's car. I'm not super mechanical, but I'm going to try my best and pray that I don't mess up her car! She has a 2007 Yaris with automatic transmission. I'm wanting to use the OEM stalk setup and I've read through much of this thread and the 2006-2011 Yaris – OEM Cruise Control Installation PDF. However, I'm not sure if her car is Sedan with power OR Sedan without power. Not even sure what that means. She has power locks, power windows, manual seats, automatic transmission, manual side view mirrors, and obviously no cruise control. I included an image from the guide here. Which applies to me? The one I circled in RED or the one I circled in BLUE
#453 |
#454 |
All this ecu p/n for 1nz engine 1500cc. Any ecu p/n for 2nz 1300 cc
#455 |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2018
2007 Toyota Yaris with Blue and Brown Wire in D3
I have a 2007 Toyota Yaris with Blue and Brown Wire in D3 no A21 pin 40. What am I supposed to do with wire coming from ECM A21 pin 40?
#456 |
Also, where can I get a Cruise Control Indicator Module? Does CTScott still have some available or is their a wiring diagram that I could build one myself?
#457 |
Ok, I looked up the electrical drawings for cruise control. D3 goes to AD4, which is a connection between harnesses, and on the other side of the harness connection their is no wire coming out to pin 40 on A21. I got extra repair terminals, so I will put a terminal in the empty side going to pin 40 and solder it to the repair terminal I install in pin 40.
#458 | |
![]() Drives: Yaris Join Date: May 2018
#459 | |
![]() Drives: yaris sedan 2011 Join Date: Oct 2016
who said me know
w/power and w/out power means? different? |
#460 |
![]() Drives: toyota yaris 06 1.3 Join Date: Sep 2019
ABOUT MY YARIS 2006 CRUISE CONTROL
HI CTScott
15 days ago i bought a 2006 gasoline 1.3 i really want to install cc and i would like your help, the car is european and my ecm number is 89661-0D310 https://photos.app.goo.gl/qqk757aZasRFupdj7 Last edited by giorgos01; 09-24-2019 at 03:26 PM. |
#461 |
Drives: 2015 Toyota Yaris L Join Date: Sep 2019
Does my american 2015 Yaris L have prewired cruise control? Hoping for just a plug and play here.
#462 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
It should just be a matter of mounting and plugging in the control stalk.
Have a look at http://yarisworld.com/forums/showthread.php?t=37205 The 2015 should only be a facelift from 2012.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#463 |
![]() Drives: 2010 sedan Join Date: Apr 2020
Hoping this thread is still alive. I am about to buy a base model 2010 4 door sedan without power locks/windows and auto transmission. Does this require just the stalk and wire? The guide seems to say it requires running wires to the ECM but a few posts here have confused me if that is needed. Since I don't have the car yet, I can't look but I wanted to get the parts.
#464 |
![]() Drives: 2008 Sedan Join Date: Jul 2017
Quick question, would my 2008 Sedan automatic require the d3 pins? I don't have power windows/locks/mirrors if that makes a difference.
#465 |
Drives: 2010 Yaris Join Date: Sep 2022
My gf has a 2010 Yaris with a stick.
I installed a cruise control stalk I bought online. The dash light comes on showing cruise control is on, but it will not engage? Do I need to add the clutch sensor? Can someone please repost the clutch sensor wiring instructions? |
#466 | |
as for the wiring..a lil searching and you should find it |
#467 |
![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
Read the last post here: https://www.yarisworld.com/forums/sh...t=33750&page=9
#468 |
Drives: Toyota Vios 2011 MT Join Date: Oct 2022
Hi every one!
I'm fom Viet Nam , my car is toyota yaris/vios 2011 Mt, Asia production, can I install cruise control for my car? thanks alot! |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
