Old 11-30-2017, 06:50 AM   #4
tmontague
tmontague's Avatar
The above posts will help with high speed wander but unfortunately not a lot for cross winds. The yaris/echo are light cars with a large cross section, aside from adding a lot of weight or cutting down the roof, strong cross winds will always require your full attention when driving.
I have 7 inch wide rims, I'm lowered on stiffer suspension with a rear sway bar and on tires that have almost zero wander. I still get tossed around in our strong cross winds. Going over the skyway during my commute can be a challenging task if im not beside a large truck to block the wind.
I've found relaxing my grip on the steering wheel and not fighting the wind as much helps quite a bit.
Suggestion: Fourth Generation Toyota Yaris Main Rooms SilverBack Suggestions - Feedback - Questions 3 10-21-2014 05:14 PM
Yaris T1 Upgrade CrzyCrg In Car Entertainment + Electronics (audio / video / alarm) 1 09-05-2010 06:45 AM
Next Generation Yaris Speculation 07GPWS2K General Yaris / Vitz Discussion 8 08-28-2010 10:04 AM
