![]() Drives: 2012 Yaris L, 2017 Yaris L Join Date: Mar 2012
Accidental arc to ground, help!
I was in a rush today, had a dead alternator that I was trying to change out quickly & forgot to disconnect the battery. (Big bonehead mistake). I heard a pop when it happened too.... But can't figure out what went.
I got the alternator swapped and the car now starts, but.... lights are on on the dash (abs, tc, brake, airbag...) No power steering, no locks, etc.... Seems like a main relay or fuse, but fuses look good. Any suggestions? Where to start? |
Check the fusible link located just behind the positive terminal ibn the main positive wire. It may have popped
Yep! Found it! Now I just need a new one is this a dealer only part?
I used a standard fusible link(14g wire type) as a temporary fix, just pushed an all through the cable, put the link into it, taped it up, and put the other end on the battery side... Car runs & everything works. Bought a new fuse thing from the stealership, ~$25.
you probably could have gotten one way cheaper at an auto wreckers
![]() ![]() Drives: 47 2013 yaris l hatchbacks Join Date: Nov 2016
Hope this helps.
![]() Sent from my Nexus 6 using Tapatalk |
Fusible link block assembly.
| Increased ground clearance between 2008 and 2010 Sedan | unclenefeesa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 01-17-2013 05:49 AM |
| rare arc super induction box , oil cap , rad cap | blacksandiegovitz | Items for Sale by private party | 7 | 03-28-2012 01:43 PM |
| Stereo Ground Wire | xiii | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 12-22-2011 07:00 AM |
| Aux in ground loop noise | xavierq | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 06-10-2011 02:47 PM |
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 01:56 PM |
