Old 12-11-2017, 12:44 AM   #1
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
Give me some new tire recommendations!
Hello everyone!
I haven't posted on this forum in a few years, mostly because I've never had any problems with my Yaris. Bought this car new in 2009, and I still have the original tires from the factory! The reason is because I only have about 25,000 miles on the car (no, that is not a typo), so there has been very little wear and tear on the tires. The treads are fine, but while putting in air today, I noticed that there are small cracks in both the tread and the sidewall. Obviously, those are age-related, and I figure the safest thing to do is to just go ahead and replace the tires. They're at least nine years old anyway, so why not.
Anyway, this is my first car, and this is the first time in my life that I'll be buying brand new tires. Does anyone have any recommendations for a make/model of a good all-season tire? Note that I take public transportation to work, and it's been seven years since I'd been on a roadtrip. I use my car nearly exclusively for running errands on the weekend, and it stays in the garage during the week. So, in a tire, I'm looking for quality, safety for snow and ice (I live in Ohio), longevity, and, if possible, good road feel. So, no sports or performance tires, etc. Just something that will get me to and from the grocery store, with the occasional highway driving. Price isn't an issue, I just want great, quality tires that can easily last another nine years.
Hamster is offline   Reply With Quote
Old 12-11-2017, 06:07 AM   #2
CB900F2
Drives: 08 Sedan
Toyo Celsius
CB900F2 is offline   Reply With Quote
Old 12-11-2017, 06:18 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Michelin Defender A/S
Old 12-11-2017, 10:28 AM   #4
atomic_hoji
Drives: 2018 Yaris SE 5MT
I had great luck with a set of Nokian WR G2s - they ran well as an all season, but also performed decently in the winter. Unlike general all seasons that are garbage in cold weather, the WR G2s actually stuck to the road and pushed through the snow pretty well - I wouldn't say as well as a dedicated snow tire like the Hakkapalitta, Blizzak, etc.. but they were good. These were on a Mk4 VW Jetta TDI and I live in a rural area, so they were run up and down main highways and (often unplowed in the winter) county roads all year round. The WR G3 is out now, which I don't have any experience with, but if I weren't running dedicated snow tires on my cars I would have a look at when shopping for sure..
The Nokians will likely be pricey, but like anything it's definitely worth doing some research and deciding what fits your requirements and budget best.
Good luck!
-- Adam
atomic_hoji is offline   Reply With Quote
Old 12-11-2017, 10:23 PM   #5
Hamster
Hamster's Avatar
Thank you, thank you everyone! Wow, such a tough decision. I did some quick internet research into all these suggestions, and they're all great tires! I'm intrigued by the Nokian ones, since you, atomic_hoji, report a good experience with them in ice and snow. Safety is my top priority. But the Michelin Defenders and Toyo Celsius are apparently really good, too! I'm going to get new tires installed the first week of January, so I have a couple weeks to decide which ones I want before I need to order them. Cost of tires is a non-issue, and I can easily afford to splurge on a set of good ones.
Old 12-12-2017, 02:10 PM   #6
Hershey
General Altimax Arctic . Can be purchased for $74 or so at Wal-Mart . They have very deep siping to base of tire to help with grip in snow and ice. Start at 12/32s' and should last for 4 years or more . Can be studded too . Usually for $17 or less per tire .
Old 12-12-2017, 02:24 PM   #7
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I plan to go with Yokohama YK740 GTX at Discount Tire.
https://www.discounttire.com/buy-tir...40-gtx/p/27357
Kalispel is offline   Reply With Quote
Old 12-12-2017, 09:01 PM   #8
Hamster
Hamster's Avatar
Hershey - I looked up the tires you suggested. The problem is that they are a winter tire. I know that having a winter tire is ideal, but I just don't have the space in my 1950's-built garage to store an extra set of tires (and building a shed to store them isn't an option, since sheds in my area attract burglars). So, I'm stuck with all-season, which is what everyone around here uses anyway. But anyway, thank you for your reply!
Kalispel - I did a quick lookup, and the Yokohama's appear to be a good option! I will definitely consider them.
Old 12-12-2017, 09:31 PM   #9
Hershey
The General Altimax RT43 T-rated or H-rated. Used the H-rated for one winter and they did well. The T is rated slightly better for winter by Consumer Reports. The H has a firmer sidewall. They are both under $65 at Walmart. See tire reviews at Walmart and TireRack.
Old 12-13-2017, 09:16 PM   #10
Hamster
Hamster's Avatar
Thanks Hershey, I looked up the General Altimax, and it does indeed have a lot of great reviews on the websites you listed, and others. I will add it to my list of tires to consider!
Old 02-28-2019, 07:18 PM   #11
KALISPEL II
KALISPEL II's Avatar
Drives: '26 Mazda 3 Select-Sport Sedan
I finally replaced the factory 195/50-R16 tires on my Yaris the other day at Discount Tire. My car has 49K miles on it now (I've owned it for a bit over 3.5 years now), & the tread depth was barely in the yellow zone on the tread depth gauge. After a bit of updated research on tire options, I decided to go with the recently-released YOKOHAMA all-season (rated 65K) touring-performance tires AVID ASCEND GT in the same 195/50-R16 size. Those are the Yokohama tires that replaced the Yokohama YK740 GTX series tire.
My initial impressions are that the ride is better, the tires feel more grippy, & the road noise is less compared to the tires that they replaced. I'm happy with my tire choice - though I did have to wait a week to get them delivered from Yokohama factory to my local store, due to "uncommon tire size for the U.S. market".
https://www.discounttire.com/buy-tir...end-gt/p/37564
I paid $111 base cost per tire ($578.55 total cost installed), but ordered & paid for them during the weekend where a 10% Visa Gift Card rebate was in effect. I plan to donate the rebate gift card balance to an animal rescue organization when it arrives.
2026 2.5L NA Mazda3 Select-Sport Sedan 6-AT FWD (w/Chrome-Delete) - Soul Red Crystal Metallic - Built in Japan
KALISPEL II is offline   Reply With Quote
Old 02-28-2019, 08:16 PM   #12
dogsridewith
Drives: 2007 2-door hatchback
What is the rim size?
Old 03-11-2019, 09:46 PM   #13
Hamster
Hamster's Avatar
Now this this thread has been revived, I feel really embarrassed to say this but....I still haven't bought new tires! Why? Well, it's not a money issue. What can I say, I just keep procrastinating! I now have put on an additional 3,000 miles on this car since my original post. Also, after being educated about how bad city driving is for a car, I now drive almost exclusively highway miles. I now drive to a town 25 miles away to do my grocery shopping. Anyway, the cracking hasn't really gotten any worse, so I've just been closely monitoring the tires. I really wanted the Michelins, but Michelin no longer makes an all-season tire for the size the Yaris needs. That's what I get for procrastinating. I will definitely consider the Yokohamas. Now that I've been doing a lot more highway driving, I would really appreciate having less road noise.
Old 03-11-2019, 11:03 PM   #14
kimona
kimona's Avatar
What size are you looking for???
185/60/15: https://www.discounttiredirect.com/b...-%2b-h/p/32521
195/60/15: https://www.discounttiredirect.com/b...-%2b-h/p/32512
185/65/14: https://www.discounttiredirect.com/b...-%2b-h/p/32496
Old 03-12-2019, 10:06 PM   #15
Hamster
Hamster's Avatar
My door jamb says P185/60R/15, so that would be the first link you posted. Are these tires a new product? If so, I'm really happy that Michelin is making tires in my car's size. I did a search months ago, and I couldn't find anything. Their tires are very good quality. I've got family members with Michelins on their cars, and the tires handle incredible well on snowy streets, and road noise is very minimal.
Old 03-12-2019, 10:31 PM   #16
kimona
kimona's Avatar
I've had Michelin Defenders and they were great! Right now, you can get a set of them for $70 off, plus $50 off if you get their C/C.
$440 - $70 - $50 = $320, no tax, free shipping.
Old 03-12-2019, 11:02 PM   #17
Hamster
Hamster's Avatar
I looked on Discount Tire's website, and I saw that the $70 rebates offer expires on March 16. Yikes! I'm a master procrastinator, so that's a little too soon for me. But Michelin has rebates all the time. If I ultimately decide not to act in the next few days, I'll just wait for the next offer to roll around, which I'm sure won't be too long from now.
Old 03-13-2019, 09:21 PM   #18
kimona
kimona's Avatar
Why procrastinate? Git 'er done!
tires
high mileage highway tire for SE adio51 Third Gen Yaris General Discussion 2 12-08-2012 12:00 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
