![]() Drives: 06 5door Join Date: Nov 2017
Ok just for future reference, it's not quite a simple pry-off. The top clip is a standard trim clip (white plastic peg type) which can be pried carefully (best not done in cold weather). Two bottom clips are integral and have a plastic bit that needs to be pushed out of the way or they will break.
| 2008 Toyota Yaris passenger side view mirror change | KOOCHO | DIY / Maintenance / Service | 1 | 12-01-2012 09:52 PM |
| Driver Side Mirror - Can This Be Replaced Easily? (Image Attached) | Yarismo123 | DIY / Maintenance / Service | 3 | 10-06-2012 10:04 AM |
| Taking out "Deck Trim Side Panel Assembly" from 2007 5-door (for cleaning purposes!) | lech7 | DIY / Maintenance / Service | 3 | 01-03-2012 08:56 PM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
