Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I know there is some mis-information out there on the quality of Konig wheels, So I wrote this review to show the truth.
http://www.armstrongfamilyblog.com/a...-season-review |
Solid review, glad the rims are working out for you. I also really enjoyed mine for DD'r use and their weight was unbelievable.
I should note that both my dial-ins and my now hypergram's both had very poor balancing my the factory in all 4 rims in both types. Minimal wheel weights were able to correct this and I've had no issues at high speeds but the tire tech complained and said they were brutal with just the rim and he's never seen such bad balacing before. Now for the price of the rims I don't mind and since it can be easily corrected it isn't really an issue. But this is important to note as some people may be alarmed when they get their new Konig's. You get what you pay for and these are great rims for the price but don't expect precision manufacturing from a sub $1000 rim
#3 | |
Data doesn't lie
Are the paint marks on your tires matched up to the valve stem location on the wheel? If so, then again if you install a "used" tire onto the wheel the tires balance has changed from wear. Also, if minimal weights(less than 2oz) were used to balance the wheel/tire assembly then you have a solid match. |
| Tags |
| kong dial in, wheels |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
