Old 03-14-2018, 07:40 PM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by David C View Post
The DRL relay is simply a triac in serie of a parallel ground of the low beam that takes about 3.5v off the line. Since I have LED's everywhere on the low and high, no point in running them at a lesser voltage. Much easier to just disconnect the relay and wire in the parking lights or any other light from an ignition circuit, so you still get DRL whenever the key is on run even without the engine running, but you don't necessarily get stuck with headlight power when you want to drive around quietly (like drive in theaters or outdoor exhibits). And it's quite a bitch to wire anything to that DRL harness due to its location and how short the harness is. In my case Im happy with the way it is after giving it much thoughts. However I picked up high amp diodes to have a parallel ground for the LED light bars and the foglights on a switch on the dashboard, so I can turn them on independently of the high/low beams too.
Huh? Last time I measure the voltage out of the DRL at the H4 harness, I was getting 12v.
I was like, fine, connect the blue wire to the orange wire of the fogs, then fog relay started flicker. A small cap solved the issue.
I believe you also lose the parking brake light on the dash when you remove the module.
Oh yeah, I can also control my fogs independently from the headlights as long as the DRL works. :)
Sent from my SM-G930W8 using Tapatalk
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
LED License plate lights for Yaris Sedan YarisSedan DIY / Maintenance / Service 6 04-09-2013 04:05 PM
Sponsors List RogueYaris Sponsors Classifieds Area 14 01-05-2013 10:23 PM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
