Old 03-27-2018, 06:28 AM   #4
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
It requires 2 x 2mm diameter holes drilling into the plastic of the bumper for the rear mudflaps, into which the supplied screws (Philips type head) are fitted. The positions are marked by small dimples in the plastic. There's also a trim clip (centre push pin type) to remove underneath, refitted through the mudflap to secure. Best to remove the rear wheel for drilling access.
The front are secured by two hex. head (10mm socket or spanner) screws, should be supplied. The holes are already there, I think, in the plastic wheel arch protector shield. So no drilling required.
Illustrative fitting instructions are supplied with the Toyota mudflaps. I would advise buying the genuine article.
Just be careful tightening into plastic.
mrpj is offline   Reply With Quote
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 01:50 AM
