Old 06-06-2018, 12:25 AM   #6
RMcG
Drives: Yaris manufactured after 2007
Originally Posted by fourbangingfun View Post
Could be a small stone stuck in one of your rotors. I had the same symptoms in my 07 sedan, even took a video to show the sound I was getting at low speeds. I had to take the wheel off, remove the caliper, and remove the rotor - and the stone fell right out onto the ground. Hope this helps.
https://youtu.be/79KPXKrsZao
Thanks four,
That might be the problem. I'll check.
R.
RMcG is offline   Reply With Quote
low, noise, speed, tinkling
LOW RPM @Idle speed = Bad Volt Generation? jp_costarica General Yaris / Vitz Discussion 4 06-14-2012 04:56 PM
Low road noise in Yaris? RedRide General Yaris / Vitz Discussion 32 05-30-2010 08:49 PM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
