Old 06-10-2018, 08:10 AM   #10
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Originally Posted by stykerdk View Post
I have seat heating switch and ESP switch in that cover under the hand brake, i think thats what is there.
The hybrid has also EV-mode switch an ECO switch there, then all 4 places is used.
VW makes wiring harness for every single car, if you want to retrofit anything you will almost everytime have to draw new wires.
And very often you also need to change the electronic control modules, because VW have a lot of types and very often the low line module doesnt support the things you want to retrofit.
But the big big difference between VW and Toyota is that VW build every car to customer specifications, where Toyota offer a number of trim levels where you can take it as it is.
Would you mind maybe lifting the small plastic cover up and taking a photo of the two switches with there connectors, so I could see if mine correlates. Would help me out a lot.
It's really easy to lift it, just pull the small rubber lip by the handbrake up and it will pop out easily.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Stock Headunit Rear Connections!! mhkritzinger In Car Entertainment + Electronics (audio / video / alarm) 6 06-11-2011 12:58 PM
Unknown plug under handbrake o.molina1 DIY / Maintenance / Service 1 01-29-2011 01:35 PM
Thailand Connections!! kid chino Cosmetic Modifications (Exterior/Interior) 5 10-25-2009 11:47 AM
Any difference on Tanabe front Strut Bar VS Unknown ebay Strut Bar? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-07-2009 06:58 PM
