#1 | |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
I was reading (and re-reading) last night and went back through your thread on using the Tercel axle to solve the bind problem - which is awesome clever btw.. I took the car out again today and gave a good swerve back and forth. Seems to be only when turning left, but sounds like it's on the right side - which would be the long-side (passenger) axle, not the driver side as you found. Over-extending the passenger side? I doubt I'm tire rubbing as I"m stock height suspension and stock wheel & tire setup. I had also thought the brakes were just coated with rust and such from sitting, but confirmed today that it has a constant vibration in the brake pedal under braking. The noise when turning isn't very loud or bang like, more like a growl... On the drive the CEL/MIL and TRAC OFF lights both came on. I did a bit of searching and, not surprisingly like much of the iM parts, the brake actuator is iM specific; not shared with Yaris or even the Corolla sedan. They communicated via CAN bus, and the being the Yaris brake actuator wired to the Yaris speed sensors, etc.. they're happy, but I wonder if the brake actuator is getting garbage from the ECM and vice versa.. Will have to see. +1 Not sure what you mean by burnt.. The yellow-orange dis-colouration is the oil "under" (all over) coating. It's a waxy oil coating and is tacky and nasty to work in the engine bay - living in the salt belt it will be good for the car in the long run, but it is a p.i.t.a when wrenching. ![]() -- Adam |
#2 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
also cant you just mount up the IM brake actuator thing to the... yeah heres what you can do when thats happening is like. run it, run an OBD2 scanner while driving see if it throws any codes. I think. I'm an armchair mechanic. |
| Tags |
| 2zr, 2zr-fe, 3rd gen, t-sport |
| Toyota to Debut 2018 Yaris At New York; No Mention of Yaris GRMN | Thirty-Nine | General Yaris / Vitz Discussion | 39 | 07-01-2017 11:38 PM |
| Went and looked at a yaris Sport! | mr_miles | General Yaris / Vitz Discussion | 19 | 02-20-2012 10:28 AM |
| My UK Yaris T Sport | Matty | Photo-Video-Media Gallery | 9 | 02-21-2010 07:04 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
